Old 04-24-2013, 02:32 PM
helton333's Avatar
helton333 helton333 is offline
New Light Bar and a little help...
Added a Rigid Industries light bar - LOVE IT - just so clean - I need help with the connector that came on it - does anyone know what you call that type of connector? Obviously a 2 post for 12V, but has to have a technical name - I need to find the female - could always cut and splice something else but rather not....
Old 04-24-2013, 03:06 PM
gweaver gweaver is online now
Boat: 1988 Prostar 190
Looks like a Weather Pack connector. Common in the auto industry.
I think Summit, JEGS and places like NAPA sell them. You crimp ends on to wires, then feed those ends in to the Weather Pack connector.
G
Old 04-24-2013, 03:32 PM
Boat: Boat
Deutsch connectors ??
https://www.google.com/#hl=en&q=deut...=1920&bih=1068
Gone, surfing.
Old 04-24-2013, 04:30 PM
carlsonwa's Avatar
Boat: 99' Sportstar
can you give us more info on that light bar and some install photos. looks clean up there.
Old 04-24-2013, 05:14 PM
helton333's Avatar
Light has 2 mounting brackets that can slide to any width of the entire housing - I just lined them up with the existing accessory holes in my New Dimension (on an 03 X2) - so honestly, took 10 minutes - already had a 5 light halogen bar wired there, and couldn't find the replacement bulbs because it took the whole bulb/reflector housing which was crazy expensive and they just were not that bright anyway - so it was already wired. Just need to get make the final connection. You would have enough room to add a rear facing as well if you wanted - these have a deep heat sink in the back of the housing, so they taper nicely in the back. I saw a brand new Xstar the other day with these lights and decided to go ahead and change it all - it would take 9 of these LED bars to create the draw of the 5 old halogens - so battery savings as well. I will try to get more pics up.
Old 04-24-2013, 05:37 PM
bcd bcd is offline
Boat: 93 Larson 200 SEI, 2002 X Star, 2012 X-2
That's a female 2 pin Deutsch DT series, maybe a DT04-2P. It should say on the side of it.
Old 04-24-2013, 05:42 PM
helton333's Avatar
Thank you to all - this amount of concentrated boat knowledge, is a BLESSING to be part of.
Old 04-24-2013, 07:58 PM
carlsonwa's Avatar
Boat: 99' Sportstar
More pics would be great.
I am thinking about switching over my tower from hid projector lights to led's light like those.
Old 04-29-2013, 11:17 AM
helton333's Avatar
Finished install pics
As promised, here's the finished look - mounting to the existing drilled cross member on the New Dimensions Factory tower - brighter (BY FAR!!) than the 5 halogens. I didn't need a rear facing, but there was plenty of room to add one to the same crossbar - may have had to drill a couple holes, but it would have worked.
Old 04-29-2013, 04:41 PM
carlsonwa's Avatar
Boat: 99' Sportstar
looks great!
