Old 05-14-2012, 09:11 AM
sheckski's Avatar
sheckski sheckski is offline
Boat: 2000 205v ltr
stiff stearing
Took out our 2000 205 v for the first run of the year yesterday. Steering was very stiff. i had replaced the steering cable last year, or perhaps the year before. I know there is a grease nipple on the cable. Would a hit of grease help loosen up the cable? Do i need to open the end when adding grease? Otherwise any suggestions on how to free the steering up without having to replace the cable?
Old 05-14-2012, 09:14 AM
Boat: Boat
Greasing the cable is a yearly maintenance to do. You should also take a look at the rudder port and see if there is a grease fitting on it as well. If not, you should consider pulling the rudder out and greasing it manually.
Tim
Gone, surfing.
Old 05-14-2012, 09:30 AM
sheckski's Avatar
Boat: 2000 205v ltr
I had been told by my dealer that greasing the cable will build up pressure inside the cable and actually make it stiff. Any truth to this? if so, is there any guide as to how much grease, if i open the end of te cable, etc? i do have a fitting on the rudder and will hit that as well.
Old 05-14-2012, 10:14 AM
Table Rocker's Avatar
The Zerk fitting on my cable does not have a ball in it. That way it doesn't hold pressure. Yours should be the same.
It's a good idea to put a shop rag over the fitting after you grease it. If you fill it up an then crank the steering, grease shoots out like a squirt gun.
Old 05-14-2012, 10:38 AM
Boat: Boat
It always helps to cycle the steering while greasing the rudder port. Also, there should be a grease fitting on tiller arm where the cable is bolted. See TRs post about the cable fitting.
Tim
Gone, surfing.
Old 05-14-2012, 10:39 AM
Boat: Boat
Let me rephrase that. Not the tiller arm but the L shaped bracket the cable bolts to.
In post #16 of this thread you can see the bracket.
http://www.mastercraft.com/teamtalk/...?t=8305&page=2
Tim
Gone, surfing.
Old 05-14-2012, 12:02 PM
19_Skier's Avatar
19_Skier 19_Skier is offline
Boat: 2001 19Skier
Mine was really tight last year and I thought a new cable was in my future but with some new grease to the rudder and the two fittings on the cable it's as good as new again!
Old 05-14-2012, 12:08 PM
Steering cable replacement is eventually going to be required. Greasing annually will give you a longer life from your cable.
- Peter
TIRE & WHEEL SALES
email:tiresplease@gmail.com
WHEEL SPECIAL
Two 14" Aluminum wheels $195
Two 15" Aluminum wheels $215
Four 14" Aluminum wheels $370
Free Freight within lower 48
Old 05-14-2012, 12:13 PM
Greasing annually and keeping a dry bilge will extend the life of your steering cable.
Old 05-26-2012, 11:36 AM
dfield55 dfield55 is offline
Boat: Mastercraft X2 2005
I have a 2005 X2. Steering was great at low speeds and stiff at anything above. Had mechanic replace the cable with new Teleflex TFXtreme. Wow. What a difference. One finger steering at any speed. Well worth it in my opinion.
