Old 05-13-2012, 10:03 AM
markismm's Avatar
markismm markismm is offline
Boat: 1984 Stars and Stripes
First of all those brackets do not look to be OEM. I would assume that someone has done some work on them before. In either event I have had to rework the ones on my 84 now. Plced backing plates on the top two bolts and put bigger lags on the bottom. Solid as a rock now.
Old 05-13-2012, 01:02 PM
tph's Avatar
tph tph is offline
I think they are OEM removable platform brackets. Perhaps they were an option that year or someone added them at a later date. They look identical to the ones on my '89.
Old 05-14-2012, 07:38 PM
Oneday's Avatar
Oneday Oneday is offline
Boat: 1985 mastercraft stars and stripes 351w
We're do I go from here!!!! I can't get to the bolts that hold the platform!!!!
1985 stars and stripes
Old 05-14-2012, 08:13 PM
MCOCD@13 out of 10
You may have to follow cloaked instructions...this may a bigger job than you think...probably a couple of weekends or a bunch of evenings...
Old 05-14-2012, 09:48 PM
Cloaked Cloaked is offline
Boat: MasterCraft
Snap out of it and read what has been posted. >>> SLAP <<< dammit boy!
Stop the madness and do exactly what has to be done. Pull the tank, cut the floor, install thru-bolts and backing plates, button it up, and move on...
There are pictures on this forum of the entire process with detailed explanation. I can't spoon-feed you forever....
Old 05-14-2012, 09:53 PM
MCOCD@13 out of 10
Old 05-14-2012, 10:19 PM
tph's Avatar
tph tph is offline
it's not....IIRC.... the 85 is a direct lag screw into the hull. I've had to do three of them over years.
The stock '85 brackets looked like the first picture and were lagged into the transom in four locations per bracket. However it appears that some '85's were delivered with the optional removeable bracket with hardware like the second picture. This hardware is identical to the setup on my '89. On the '89, the four recessed bolts holding the backing block to the transom are through bolted with threaded backing plates that are glassed into the inner hull. This allows you to remove the block from the transom without removing the fuel tank. I'm not sure if this is the case with the '85. (perhaps they used lag bolts)
Old 05-14-2012, 11:08 PM
Lumbergh's Avatar
Lumbergh Lumbergh is online now
Boat: 1991 ProStar 190
I don't mean to dogpile, but sometimes it needs to be said:
stars and stripes, swim platform, swin deck
