swim deck gap need help!!!!!!
i just got off the lake and when i was wiping down the boat i noticed my swim deck is coming off. need to know how to fix and what i need. ( boat is a 1985 stars and stripes )
heres pics. |
Is your deal bolted directly to the transom? That's what the picture looks like?
Fishing is nothing, but Drinking with a stick. 1985 Mastercraft S&S 351w 1:1 http://www.youtube.com/watch?v=95FBtsKj3b4 |
![]() If you have the angle mounts to the transom, which you should. You may need to remove the gas tank and tighten the mounts I suggest using backing washers on the inside. The teak deck can then me realigned and screw back to those angle mounts with stainless screws.
i think it is thru bolt. i had the tank out last year. i think there is a plate on the inside.
heres one more of the bad side. and a few of the good side.
Oh ya. Your bolt broke or is pulling through the fiberglass. Need to pull the gas tank. Replace all the bolts now and definitely run backing plates or large washers. Backing plate is better use lock tight as well.
At lease it is an easy few hour fix and you need a friend to hold a wrench.
#7
I do like your platform. .
93 190 . Hypocrites, boot lickers, and crybabies…the world is full of them…. just look around - near-by . Duraflap / Kaydenco aren't worth a hoot Hose picture (internal) http://www.mastercraft.com/teamtalk/...68&postcount=8 . Last edited by Cloaked; 05-13-2012 at 08:56 AM. |
#9
93 190 . Hypocrites, boot lickers, and crybabies…the world is full of them…. just look around - near-by . Duraflap / Kaydenco aren't worth a hoot Hose picture (internal) http://www.mastercraft.com/teamtalk/...68&postcount=8 . Last edited by Cloaked; 05-13-2012 at 08:55 AM. |
#10
it's not....IIRC.... the 85 is a direct lag screw into the hull. I've had to do three of them over years.
93 190 . Hypocrites, boot lickers, and crybabies…the world is full of them…. just look around - near-by . Duraflap / Kaydenco aren't worth a hoot Hose picture (internal) http://www.mastercraft.com/teamtalk/...68&postcount=8 . Last edited by Cloaked; 05-13-2012 at 08:45 AM. |
| Tags |
| stars and stripes, swim platform, swin deck |
