using old gas
So I left a half tank in the boat last used in October and want to siphon out the gas to use in some atvs this weekend. I know leaving the gas in the lines is not good and I plan on refilling and taking the boat out really soon.
Is this ok to siphon it out? I know I've read about pump problem if the tank gets 1/4 or below but thats when its running right? If I siphon it out and then refill it before starting i would imagine it'll be ok. |
Letting the tank go below a 1/4 tank is a problem predominately only when the pump is running as the gas is required for cooling the pump.
But, there is some evidence that letting the pump sit dry is also bad for the pump bearings/seals. Whether this is true, I have no direct evidence. You may want to replace the removed gas with fresh stabilized gas.
2008 X star, 2005 X2 |
The 1/4 tank rule is an issue for the in-tank electric fuel pumps that MC started using in about 2000. If your 94 doesn't have an in-tank pump, I wouldn't worry about that.
Siphoning and refilling later won't cause you any problem.
'04 MariStar 230VRS/MCX |
I have to say I don't hate my ex-wife but I was way lucky she decided to try and "find herself" .
___________________________________________ ________________________________ |
![]() Wrong thread big guy. |
Actually in the end it all worked out for the best, I have a great wife and family and she is minus 1 a-hole..................... ![]()
So who is plus one?
'97 Prostar 190 - LT-1 Prior boats - 2009 X14, 2008 X14, 2005 197, 1988 Tristar 190, 1989 Prostar. |
siphoning gas=ex wife.
I think I see the connection now! ![]()
I was njskier on here. |
#10
Rollin' Gangsta Style Quote:
