Old 07-27-2012, 08:19 AM
JStock7169 JStock7169 is offline
Boat: 2010 X2
X2 Ballast Upgrade - 455 lbs
I have a 2010 X2 I am adding a 455 lb sac to the port side rear locker. I have the kit and will be installing it this evening when I get to my cabin where the boat is at. Everthing is pretty straight forward, but figured I may ask if anyone has done this, and if so what did they reset the ballast timers to in order to fill the port side and the new bag? How many minutes?
Also where exactly is the port side ballast pump located at, so I can unplug it as I am reprogramming. Rear Seat?
Thanks
Jason
Old 07-27-2012, 10:19 AM
Boat: 2010 X2
After a little more research it looks like I can adjust the ballast timers with the BIG display. Is that correct?
Thanks
Jason
Old 07-27-2012, 01:01 PM
tmacx2's Avatar
tmacx2 tmacx2 is offline
http://www.mastercraft.com/teamtalk/...ad.php?t=47223
I did this a few months ago but I must give all the credit to a previous thread I found by Roonie's. (There is a link to his thread in mine.) I reset my timer on the BIG. Increased mine to 7 minutes but you may be able to get away with 6.
Old 07-31-2012, 04:26 PM
Boat: 2010 X2
I was able to get it installed in about 20 minutes, had to really heat the hoses up with a hair dryer to get them to slide over the barbed fittings. I adjusted my BIG to 8 minutes and it seems to be perfect. The wake is much better now and surfing is great, worked on a 360 for two days, got close, i'll get it by the end of summer. LOL
Thanks !
