Motor/Tranny exposed, what now?
I pulled the rear seat back off my 02 X30 so I can get it reskinned in the off season. I went ahead and pulled the middle insert and I was wondering if you guys had any advice on stuff I should do "while I'm in here" as I don't imagine I'll be pulling the seatback off again once I get the skin back on. I was going to do the transmission fluid anyway as part of my yearly maintenance. Any suggestions. Thanks.
If you haven't changed your fuel filter lately now would be a good time.
lubricate moving parts such as tranny shift linkages, clean air filter, clean the fiberglass under the seat...
1993 Blue Stars and Stripes Prostar Powerslot 351HO Mastercraft: Face It - If you are not a good skier behind this boat, you are not a good skier. |
Russlars is right. I change my fuel filter every year. Some might think it's overkill - beats swapping a few beers for a tow and wasting 1/2 a day for a repair.
Good time for some deep cleaning/painting of the engine compartment/bilge.
If you have more than 200hrs on the fuel pump and are going to replace the filter, then you may as well for under $100 just replace the fuel pump while you have the module pulled. Fuel pumps are notorius for only lasting 3-400hrs max on our boats. Trans fluid, yes. Trans filter if that hasn't been done in the last 1-200hrs. Grease as mayo said. Double check all the wiring/connections. Clean any connections to ground.
I'm glad I don't have to work on that engine lol. I like my DD -- everything right there in plain view with lots of room to work.
Carefully inspect any rubber hoses, and replace as necessary. If they're original they are ten years old now.
1984 Stars and Stripes Powerslot White with blue stripes. |
I love the duct tape
Duct tape still unopened in the pic though.
Jafo9 - Forget about re-skinning the seats. Just stretch duct tape over all the storage pods. You can even spice it up with fancy colors for that extra special look. Strad, I hear ya... I just switched from DD and I am not a fan of engine access on the new X2.
