1980 stars & stripes project boat-questions
This dec I bought a 1980 stars & Stripes project boat with a ford Windsor pcm original eng.
It needs a lot of TLC. I will be posting pictures and questions as I go. Any useful input is appreciated! Questions 1. What is the WOT and what should I expect in top end speed with a footer behind? 2. What weight of oil for the engine, and Trans? 3. How to I figure out the exact engine model and size for parts ordering? 4. Where can I get the following parts?: Mechanical fuel pump Sea water pump Exhaust lines-hoses Solenoid Electronic ignition conversion kit Propeller (see my propeller thread for input into selection) 5. What is the process to repair gel coat chips myself? Suppliers? 6. Anyone installed their own hot water shower using a mixer valve? Does this create a hot water loop or is there a backflow preventer? (I have tapped hot water exit lines before, but never tried mixing.) steps and parts? 7. The front tracking fin is bent to about 7pm. Can it be bent back or does it need to be replaced? Supplier? Last edited by barefootjoe; 01-06-2010 at 11:58 PM. Reason: missed question |
my signature contains the link to the manuals posted by mastercraft, oil info and trans info should be in there; as for the prop your local MC dealer or a online source such as overtons, Iboats, or the actual manufacturers site.
Tom 1988 ProStar 190 red/gray -Ford 351 -OJ 13x11 prop -Kenwood Stereo Need a manual go here http://www.mastercraft.com/knowledge/owners_manuals/ |
Welcome to Team Talk and congrats on a great looking boat.
A couple quick answers : You most likely have a 351W, although some came with a 302. Top speed should be about 44 or 45mph There have been lots of discussions about which oil to run. Do a search and you will find lots of reading. I use Valvoline 20w/50. I would replace the tracking fin. Not much flexibility there. www.skidim.com will become a great source for parts and info. Get a catalog ASAP - it will become your go to book. Search for gel-coat threads - again lots of reading. Pretty simple to do if you have some patience.
Poked around and found the info on the boat. Engine Model is PLD WR L10 It has a newer holley 4 bl carb. Can anyone tell me what size engine this is? and HP? Trans is a velvet drive model 10-17-001 |
Can you post some pics of the engine?
1986 Mastercraft Skier w/ Powerslot |
I agree. BFJ post a couple pics of the engine.
A 351 intake is about 10" wide at the front bolts. A 302 is about 8" wide.
nice boat barefoot Joe! I was hoping to find that color to match my pick up and car. I have an 81 that is sand and rootbeer colored.
Top speed of my boat in stock condition was 43 mph on a GPS, but the motor was laying over due to insufficient fuel or the points being out of wack. I am expecting around 46 out of it when I fix the ignition with a new distributor and a carb rebuild.
1981 MasterCraft 19' Skier 351W PowerSlot Deluxe Long gone is the Trans AM
It actually sounds pretty good
. Mufflers? |
Well, its 75 this weekend, CRAZY, normally we have at least 1 snowstorm in late mar/april. I am finally on starting the project, I went through the boat(s) yesterday, and here is the to do list.
First things first, to raise the $, I am selling my first boat-the bayliner, and the Glasstron I picked up for nothing last fall, I will try to remember to update with pictures as I go. Underlined items are completed. Any tips or suggestions are welcome! Raise $: Sell Bayliner: rebuild lower unit/shift cable, new bearings, new tires, rebuild carb, floor paint, Polish hull, clean seats, Convert points to rotor cap, trailer light, tachometer. Raise $, Sell Glastron, new stringers, floor, foam, carpet, bilge, Pylon, seats, lower unit seals, Paint vinyl, steering wheel, trailer lights, paint trailer, bearings, tires, gloss coat boat, rope guard ********Mastercraft List ********** Replace sea water pump / impeller Replace mechanical fuel pump Replace front n rear solenoid and / install wire from front to back solenoid Wet Exhaust hoses Replace fuel filter Replace water separator Replace driver side plug Remove and clean out gas tank, clean out fuel lines New hoses / belts New exhaust flappers / seals Replace bent bottom fin Bilge electric connection Attach dipstick tube Spark plugs/ wires / convert to cap/rotor Oil / filter change New battery Prop shaft alignment / packing Attach and support swim platform Bearings Wheels tires Fix Trailer lights Mount license plate Mount PA stickers Spare tire mount Fix gelcoat on bottom ACME 541 New speedometer, lines, and feed tubes Fix trailer fender crack Mount driver seat Emergency Prop replace tool/kit Polish windshield Wax gel coat Tower / bimi? Barefoot boom Ethanol fuel addative convertor Travel straps/tie downs? |
| Tags |
| 1980, barefoot, fuel pump, propeller, stars & stripes |
