Old 06-02-2008, 10:58 AM
jdredfield jdredfield is offline
Boat: 1995 Prostar 205
Overheating issues on a 95 prostar
I have a 95 prostar 205 with about 300 hours on it and I have never had a problem with it. I ran it in a river last week and could've picked up some trash but as I run it for a while at speed the temperature slowly rises until it gets close to 220 or 230 degrees and then the engine will shut down. I have tried to flush it and I've looked at the impeller and I'm putting in a new 143 degree thermostat. Where else should I look for trash? What is the canister that is inline on the water pickup hose? It has a couple of oil looking lines coming off of it. Should I pull that? The original invoice lists the engine at 275 TBI 1:1. I am assuming I have a plain jane chevy 350. Is that correct?
Old 06-02-2008, 11:27 AM
etduc's Avatar
etduc etduc is offline
Boat: Mastercraft Prostar 205
I have a '94 Prostar 205. The canister, your talking about, is the transmission cooler. There is an intake screen, on it, that can get clogged. I preferr to remove the hose, between raw water intake and the cooler, to visibily inspect cooler. ( and hose.) Also, inspect hose after pump, for debris.
143 stat or 160 stat. Some say 160 stat, is better for performance and economy. Be sure to use a marine grade stat.
Ayyyy!
1994 RED Mastercraft 205, Chevy 5.7 TBI.
Old 06-02-2008, 11:28 AM
454Prostar190's Avatar
454Prostar190 454Prostar190 is offline
Boat: Mastercraft, Stars and Stripes, 425hp/454 Chevrolet, Actual Marineworld/Africa USA Towboat
The "canister" is your transmission cooler that runs in line with your raw water pickup for your engine. You have probably picked up debris and the line from the pickup beneath the boat to the water pump is blocked. I had the same problem and tried impeller, thermostat, another impeller etc. and learned what I now know right here. I flushed the raw water hose, trans cooler and she ran cool again! Rick
Old 06-02-2008, 11:33 AM
damaged442's Avatar
damaged442 damaged442 is offline
Boat: 1989 Tristar 190, Indmar 351, 250HP
That happened to my buddy this weekend with his 94 Maristar 225 VRS. It was running hot, and he never checked the intake screen. I took the intake line off it, it was packed with pine needles. After cleaning it out, the temp stayed at 140. Hopefully, it's that simple for you also. Good luck.
1989 Tristar 190 - Indmar 351, 250HP, 1:1, 450 hours
Old 06-02-2008, 11:36 AM
BIGBADBLUE's Avatar
BIGBADBLUE BIGBADBLUE is offline
Boat: '94 Prostar 205
Very easy to clean ... just follow the raw water line up from the bottom of the boat and you will fine it. My '94 205 has a strainer and all you do is remove the hose and clean out the strainer.
Old 06-02-2008, 11:37 AM
bigmac bigmac is offline
Boat: 2004 Maristar 230 VRS
Did you actually pull the impeller out and look at it, or just take the cover off and look at it in the pump? If the latter, you may very well have missed significant damage to it.
The effort necessary to "check the impeller" is about 90% of the effort to change it for a brand new one (plus $30, of course). I would first pull the lower hose off the transmission oil cooler and check the strainer for debris, then I'd change the impeller.
'04 MariStar 230VRS/MCX
Old 06-02-2008, 11:59 AM
These boats use a 160 degree thermostat, not a 143 degree. The only one that uses 143 is the LT-1, and that's only one of them. The main one for the cooling system is 160. A 143 degree 'stat will waste gas and a cold engine isn't as efficient as a warm one.
Old 06-02-2008, 01:28 PM
BrianM's Avatar
BrianM BrianM is offline
Boat: 1988 Prostar 190
Jim I am sorry but this is wrong. I talked to Indmar specifically about this when I changed my t-stat. The one that was in it when it came from Indmar was a 143. That is confirmed by what was in mine and what I replaced it with, Although the t-stat is a 143 the boat operates in the 160 degree range. I ran a 160 tstat in mine for a short time and it would allow the boat to run in the 180 range which is a bit hot.
Old 06-02-2008, 05:22 PM
chico chico is offline
Boat: 94 205 prostar
I`m with Jim,indmar told me to use a 160 also.Mine works fine.
Old 06-03-2008, 12:26 PM
Thanks for all the replies. I pulled the water intake hose at small canister and found about 3 inches of debris on the screen which I probably picked up in the river I was skiing on. I am suprised the boat ran at all. Anyway, thanks for the help.
