TeamTalk
-   For Sale: Parts & Accessories (http://www.mastercraft.com/teamtalk/forumdisplay.php?f=56)
-   -   2003 X2 Hard Tanks (http://www.mastercraft.com/teamtalk/showthread.php?t=45742)
Nutter281 02-19-2012 06:57 PM
2003 X2 Hard Tanks
Hi Guys,
Pulled the hard tanks out of my 03 X2 last weekend to upgrade to the 750s. IF, for whatever reason, someone is looking to replace theirs (or add them where they may not have already existed) shoot me a PM - otherwise I'll probably just throw these in my attic. I'll have these up on craigslist as well.
Thanks,
Austin
rkhodges21 02-19-2012 08:00 PM
How is the ballast arranged in the 03 X2 and which ones are you selling?
sheckski 02-20-2012 07:27 AM
pics and dimensions? Ned to see if they can be adapted for my 205 v.
Thanks
rkhodges21 02-20-2012 08:52 AM
I was gonna see if they would work in a 205 direct-drive.
JRW160 02-20-2012 09:15 AM
No way they'll fit in a 205 direct drive. They will definitely fit a 205v
Nutter281 02-20-2012 08:48 PM
1 Attachment(s)
I think JRW has the right of it - these are pretty uniquely shaped to hug the inner gun whales (is that the right term??) in the rear of the boat. It is both the left and right rear hard tanks that I am looking to part with. Dimensions are roughly 40"X18"X11", again, with notches to hug that inner wall. My understanding (limited as that may be :confused:) is that all 205V boats from 2001 until (and possibly later) 2005 have identical hull characteristics. So there are a lot of models that these would pair nicely with, but I'm not confident in my ability to identify all of those models.
I can take other dimensions or pictures to increase confidence as necessary.
Thanks,
Austin
snork 02-20-2012 09:31 PM
they'll fit any 205v hull
JRW160 02-20-2012 10:42 PM
They hold about 250lb each. I sold mine to a guy locally with a maristar 210 I believe. The local dealer assured him they would fit. Here are some pics of mine when I had them installed
https://lh4.googleusercontent.com/-j...20CIMG4097.JPG
https://lh6.googleusercontent.com/-v...0/CIMG4096.JPG
rkhodges21 02-21-2012 01:30 PM
Yeah. I can see that they wouldn't fit a dd from the pics of the boat. I was thinking if they were made to fit on the transom then they might work, but there is not enough room for them the way they are mounted. Thanks for the info. Do the original xstars and x2s come with ski locker or under bow seat ballast tanks? If so, they should fit a 205 dd right?
JRW160 02-21-2012 02:41 PM
They come with ski locker sacs. They are custom bags that are 80x10x10. I was quoted $450 for a replacement. You could go with a fly high tube sac for $130, but it holds about 70lbs less.
http://www.wakemakers.com/fly-high-tube-sac.html
